12 years agoconfiguring 2 FPGAs in PS mode
I have 2 FPGAs Cyclone IV in my board design and I want to be able to reconfigure them by the CPU separately, means reconfigure one while the other is still in user mode . Which signals should I sepa...
12 years ago --- Quote Start --- You need to treat them as completely separate devices, eg., all the PS control signals need to be separated. If you need to have the devices configure in two-device PS mode at some times, and then in single device PS mode at other times, you can use tri-state buffers or bus-switches on the PS signals, and use the CPU to select the appropriate operating mode. Feel free to post a diagram showing what you are trying to do, and forum members will take a look. Cheers, Dave --- Quote End --- Thanks Dave, it is not clear for me why should I separate the DATA and DCLK signals? and even the nSTATUS and Config_done , as they are open drain according to my knowledge can stay connected together . Can you explain more broadly your recommendation.
