12 years ago
Configuring 2 Cyclone III's from one EPCS16 Using 2.5V
My FPGA configuration signals an error by pulling the nStatus line down at the end of configuration and starting over (and over and over).
1. I am attempting to configure two EP3C40F484C8N's (Cyclone III) from a single EPCS16.
2. Each FPGA has a different pinout and different logic.
3. "Generate compressed bit streams" is selected for both projects in the Device Configuration Settings and "Compression" is selected for both of the project "SOF's" under properties in the "Convert Programming Files" utility. PMC_FPGA.sof is set as the AS configuration master of the two and IO_FPGA.sof is set as the PS configured slave FPGA. The PMC_FPGA.sof is listed above the IO_FPGA.sof under "SOF Data" within the "Convert Programming Files" utility.
4. I believe I have followed the schematic layout for this multichip configuration with all of the pull-ups, pull-downs and buffers and data/dclk series terminations. All EXCEPT the bits described below.
5. The two FPGA use LVDS IO in banks 1&2 and 5&6 and hence VCCIO in these banks is connected to 2.5V.
6. The EPCS16 device is a 3.3V part and decided to use a FET voltage converter (SN74CB3T1G125DBVR) on the signals between the EPCS16 and the Master FPGA and the Buffer Drivers to the Slave FPGA.
7. The signals that through the translator/voltage are DATA_0, DCLK, nCONFIG, nCE.
8. I have not analyzed the full serial data stream during configuration, but all of the signals appear to be behaving in an expected manner. The Data and clock signals are nice and clean.
9. The ASDO signals into the EPCS16 have a high logic level of 2.2V. The EPCS16 has a 1.98V V high in minimum. Seems OK.
10. MSEL lines on the AS device are msel(3..0) = 0011, on the PS device msel(3..0) = 0000.
11. The entire circuit (both FPGA's and EPCS etc.) are layed out in a 2" x 2" space.
Q1. There was a previous reply to a post that warned about signal propagation delay through voltage translators. Do you know what this warning may have been?
Q2. What else can I check?
    --- Quote Start ---
    Yes I will give the JTAG a go, but I cannot isolate the nStatus's and Config_Done's.
    --- Quote End ---
    That should not matter for this test.
    --- Quote Start ---
    If one of the devices feel that it has not been configurated I will not get Config_Done going high. The Quartus programming tool will report this as an error. I do not know what nStatus will do? I will try this.
    --- Quote End ---
    If the first device is configured from EPCS, and the EPCS is setup to ignore CONF_DONE assertion, then it should configure the first device, and be done. CONF_DONE will not assert, but the first FPGA will be configured, and just "stalled" waiting for CONF_DONE to be released.
    If you then program the second device via JTAG - while bypassing the first device - then the second device should configure and release CONF_DONE, and both devices will enter user mode.
    Cheers,
    Dave
    Ok, I am back. Going home and fixing dinner for the kids comes earlier here in Illinois. Thank you for your suggestions. I will be trying out your suggestions as soon as I go get some coffee.
    Also, over the weekend I was reading about the advanced functions in the "Convert Programming Files" utility. It appears that I can disable the Config Done error check, modify the "Program Length Count", and pad bytes onto the bitstream (http://www.altera.com/literature/hb/qts/qts_qii53022.pdf). Any experience with these adjustments ?
    Coffee first.
    Ok, I did the following to load my two FPGA's separately, and got both FPGA's doing their thing.
    1. Used "Convert Programming File" (CPF) utility to combine the two *.sof files into a *.pof for loading into the EPCS16, for programming the two FPGA's.
    1a. In the Advanced menu of the CPF I selected the "Disable AS/AP mode CONF_DONE pin error check" check box. It had previously been checked but grayed out. I am not sure what being grayed out means (?).
    2. Loaded the EPCS16 with this *.pof. Powered down. Powered back up. And ...
    a) No blinking lights, FPGA logic not running.
    b) nStatus High and NOT pulsing low. Not re-configuring.
    c) nCEO Low and not toggling.
    d) Config_Done (OR'ed from both FPGA's) Low, not happy.
    e) Init_Done from first FPGA Low, not happy.
    3. Attached USB Blaster to JTAG port for second FPGA and loaded second FPGA with its own *.sof.
    a) Blinking lights from both FPGA's. FPGA logic running in both FPGA's.
    d) Config_Done (OR'ed from both FPGA's) High, happy.
    e) Init_Done from first FPGA High, happy.
    OK, mystery fans, what is my problem loading both FPGA's from the EPCS16 and having them work ?
    My Speculations:
    1. When I selected the "AS/AP mode CONF_DONE pin error check" I got the FPGA's to relax about
    the error in the configuration (wherever it is) and this allowed me to program the second FPGA through the JTAG.
    2. Signs indicate trouble with the configuration of the second FPGA from the EPCS16.
    Also Noticed:
    When loading the EPCS16 using the USB Blaster and the Quartus II Programmer utility the process goes through the following. I noted that the "Programming device 1" step quits and moves on to verification when the "Progress Bar" in the top corner of the window has only reach 35%.
    Info: Device 1 silicon ID is 0x14
    Info: Erasing ASP configuration device(s)
    Info: Blank-checking device 1
    Info: Programming device 1 <<<<<<<<<<<<<<<< Quits when progress bar has only reached 35%
    Info: Performing verification on device 1
    --- Quote Start ---
    --- Quote End ---
    Yah, progress!
    --- Quote Start ---
    --- Quote End ---
    Not sure about this one. I've always used PS/FPP to configure chains of FPGAs.
    Hopefully someone with a similar setup to yours can comment.
    You should also try filing a Service Request with Altera. You now have a good description that shows how to get the chain to work vs fail, so Altera may be able to suggest a few tests.
    Cheers,
    Dave
    --- Quote Start ---
    Also Noticed:
    --- Quote End ---
    Read the contents of the EPCS device and see whether they match what you expect.
    EPCS is just SPI flash, so its easy to read it.
    Do you have an AS header on the board, or are you using SFL to access the EPCS device?
    I probably have some example code I can send you.
    Cheers,
    Dave
    I performed another variation on the programming of the FPGA's. This time I UN-Checked the "Disable AS/AP mode CONF_DONE pin error check" check box.
    in the Advanced menu of the "Convert Programming File" (CPF) utility.
    Also, I disabled the "Auto-restart the configuration after error" check box in the Devices Settings for the FPGA's and then recompiled them.
    This is what I got
    4. Loaded the EPCS16 with this *.pof. Powered down. Powered back up. And ...
    b) nStatus LOW and pulsing. Not re-configuring. <<<< this time the Config Done error was detected and indicated by nStatus.
    e) Init_Done from first FPGA High, happy (?). <<<< Init_Done seems to indicate things are well but the FPGA logic is not running (?)
    5. Attached USB Blaster to JTAG port for second FPGA and loaded second FPGA with its own *.sof.
    Info: Device 1 contains JTAG ID code 0x020F40DD
    Info: Configuration succeeded -- 1 device(s) configured
    Info: Successfully performed operation(s)
    Info: Ended Programmer operation at Mon Nov 04 09:57:52 2013
    nStatus still Low. No change in signals from step (trial) 4. above.
    6. Repeated the steps with the "Disable AS/AP mode CONF_DONE pin error check" check box checked and got the same results as before for this case.
    My Speculations:
    3. Init_Done is not valid unless nStatus is High.
    4. A Config Done Error is probably being signaled by the second FPGA and by checking the "Disable AS/AP mode CONF_DONE pin error check" check box, the nStatus will not see this and go High at the end of the configuration cycle.
    5. Programming via JTAG will not get things going if nStatus is indicating an error
    --- Quote Start ---
    I am using the standard 10 pin AS Header for programming the EPCS.
    --- Quote End ---
    Send me an email (to my forum name) and I'll send you an application that can read/write the EPCS.
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    I believe I have already mentioned to you that this is an optional output, and as such it is meaningless until near the end of configuration.
    --- Quote Start ---
    --- Quote End ---
    CONF_DONE does not signal errors, nSTATUS does. CONF_DONE is held low by the first device until it configures, at which point it remains low, because the second device is not configured.
    --- Quote Start ---
    --- Quote End ---
    Can JTAG be used to program both devices at power-on? If so, then the issue is likely related to the EPCS configuration file contents.
    Cheers,
    Dave
