BQi's avatar
BQi
6 years ago
Configure local jtag server option
客户在使用quartus pro 19.1的时候 发现windows版本的programmer里面---Hardware setup----JTAG Settings---Configure local jtag server是可用的
但是在同样的19.1 Linux的quartus pro中是灰色的
客户试了18.1也是如此 standardalone programmer也是如此 只要是Linux的版本 就没有这个选项
请问如何解决
  • JohnT_Altera's avatar
    JohnT_Altera
    Please run "jtagd --user-start --config ~/.jtagd.conf" in terminal then you should be able to enable the remote jtag.
    JohnT_Altera
    Do you run Quartus programmer as root? You need to have the access in order to enable it.
    • BQi's avatar
      BQi
      Sure,I have log in as root
