14 years agoConfigure Cy4 Dev Kit EPCS via USB-blaster?
I want to program my Cyclone IV GX Dev Kit ECPS via the J16 header. No header was populated so i soldered one onto the board. I then connect to Quartus II via USB-blaster dongle. No device is detected.
Is is possible to program EPCS on the Altera dev kits via USB-blaster? Thanks.3 Replies
Thanks, much appreciated. I will look into the updated Altera MAXII design / instructions.
There's a bug in Cyclone IV GX Dev Kit's MAX II program which prevents ECPS programming.
I tried to program the EPCS using the JTAG indirect method (JIC) through embedded USB Blaster, but the programming failed. We filed a Service Request to Altera and they found that some of programming signals of Cyclone IV GX are not release to tri-state by MAX II thus preventing the EPCS programming. Altera's Service Engineer created an unofficial MAX II program, which puts those lines to tri-state mode. However, with this modification the board can be booted only from EPCS (i.e. the boot selection switches have no effect). I created that service request in September 2011, but I haven't noticed that Altera had yet fixed this bug in kit's software. You might want to file your own Service Request to Altera. You can reference our SR 10830479: "Error when programming EPCS with jic-file in Cyclone IV GX FPGA Development Kit". Or you could modify the MAX II program (available in kit's sources) yourself and figure out the modification yourself (if I remember correctly all the lines common between Cyclone4/EPCS/MAXII and NCONFIG and CONF_DONE should be tristated, and MSEL pins set fixed to EPCS suitable configuration). Oh yes, I just remembered that Altera actually produced a workaround for this! Search Altera web site for article rd10032011_932. It requires manual button press during programming. However, if I remember correctly that fix also required that some buttons are pressed during boot (but that is not mentioned in that article) ... Regards, Jari - Altera_Forum
According to the reference manual, all programming option should work:
- AS through J16 and external USB Blaster - JTAG indirect through J6 and external USB Blaster - JTAG indirect through embedded USB Blaster But I don't have the DevKit and can't check it.
