YCao8
7 years agoConfiguration file in EPCS64 Device mismatch with the initial POF file
A FPGA in one of my boards cannot load configuration file from EPCS64 device after power on. when I verify the EPCS64 device content with the original pof file using Quartus II Programmer software,...
CalvinJoaz_P_Intel
Contributor
7 years agoHi YCao8,
Good day.
Can you provide little bit more information? What FPGA device are you using and Quartus II release version?
Check the supported FPGA devices for EPCS64 link below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc/cyc_c51014.pdf
Plus, what you mean by 'EPCS64 device content with the original pof file'?
Are you trying to load EPCS64 device content .pof file with same device or different device?
If you're trying to load .pof file for other devices which is not originally generated from the same device, it is not advisable to use or change for other devices.
Thank you.
