16 years agoCONF_DONE pin not going high when trying to program Cyclone III with an SOF file
I have a problem very much similar to a thread posted some time back but the solution mentioned for that ie connecting nCE pin to ground is not working in my case. Actually nCE is already connected t...
15 years ago --- Quote Start --- "trying to program with signaltap also gives no errors though it still prompts me to program my device (again and again after programming..)" Do you mean that you are not able to program through sof file also? --- Quote End --- thats the thing, i can see the programming sequence completes, quartus's console prompts "ended programming succesfully" and signaltap has a red mark telling me to program the device again, trying to start the sampling with/without a trigger option chosen changes the red mark to a yellow mark saying "jtag communication error", how can there be an error when it is beeing recognized by the programmer while pressing "find target" or using the jtag debugger successfully? --- Quote Start --- I dont remember if i had anything else other than probing at various points. Try providing a capacitor between DCLK and gnd. --- Quote End --- i see, i appriciate the effort, everything in my design is connected based on the cyc III datasheet so if it asks for a capacitor im pretty sure it has one, though i will go and check as soon as i can --- Quote Start --- Check for any reset that you may have provided to fpga . you can also connect an LED to any fpga pin and drive that to see if fpga is configured anytime --- Quote End --- another thing id like to add is that my design did function on previous versions, trying to program 100% previously working back up sof's failed as well but it did used to work for several months before this problem occured
