AlexHalf
2 years agoCONF_DONE pin failed to go high problem
Hello I am using EP4CGX150CF23C8N FPGA. Configuration is done in AS mode from EPCQ128ASI16N flash. All I/O banks are 3.3V. FPGA initial programming done through JTAG with Terasic USB blaster. Attach...
BrunoRCast
1 year agoHi, I had the same problem using the ep2, I solved it by powering the card with an external 5vcc power supply.
