AlexHalf
2 years agoCONF_DONE pin failed to go high problem
Hello I am using EP4CGX150CF23C8N FPGA. Configuration is done in AS mode from EPCQ128ASI16N flash. All I/O banks are 3.3V. FPGA initial programming done through JTAG with Terasic USB blaster. Attach...
FakhrulA_altera
2 years agoHi HAlex,
Could you try to connect the 0ohm resistor for nreset below?
Fakhrul
HAlex
2 years agoHello
Actually this 0-ohm resistor is do connected on the board even according to the flash datasheet it can be left unconnected.
Thank you.
Alex
