AlexHalf
2 years agoCONF_DONE pin failed to go high problem
Hello I am using EP4CGX150CF23C8N FPGA. Configuration is done in AS mode from EPCQ128ASI16N flash. All I/O banks are 3.3V. FPGA initial programming done through JTAG with Terasic USB blaster. Attach...
Farabi_Altera
2 years agoHello,
Do you have further question?
regards,
Farabi
- HAlex2 years ago
Hello
The NCE pin is do connected to GND as shown in the attached PDF of first message.
My questions as I posted:
1. Can it be that all this caused by jic files?
2. You think that maybe the issues I have are because of defected initial burning equipment like USB blaster or momentary problems in power supply that damaged 2 FPGA's?
3. You think that I can ignore these phenomenon based on fact that I have few hundreds of working boards (even they burned only once from JTAG, while all updates if were needed were done from serial port with .flash files) or I must dig in my design in searching design issues?
Thank you
Alex
