AlexHalf
2 years agoCONF_DONE pin failed to go high problem
Hello I am using EP4CGX150CF23C8N FPGA. Configuration is done in AS mode from EPCQ128ASI16N flash. All I/O banks are 3.3V. FPGA initial programming done through JTAG with Terasic USB blaster. Attach...
HAlex
2 years agoHello Fakhrul
1. I tested with JTAG cable only 2 boards and with both of them have the same issue. Third board was burned in a different way - through remote update option (RS232 and not from JTAG).
2. I tried to burn 'damaged' boards with different validated jic files, also with simplified jic with empty project (just pins were defined) and even tried to download only sof file.
3. The screenshot of the message attached.
Thank you.
Alex
FakhrulA_altera
2 years agoHi HAlex,
There's a KDB mentioning this kind of error, would you try to check this out? Sorry I may have overlooked your comment.
