Agdepusen
8 years agoCONF_Done, nStatus not fully released (expected 3.3V, is 2V)
Hi, this is probably my 20th Altera board, but this error puzzles me. It's a modification to an existing design which works fine. Power cycling is good. All supplies is present and stable JTAG s...
AnandRaj_S_Intel
8 years agoHi,
- Does the nSTATUS signal low from the beginning right after power up? Or during in the middle of configuration process, the nSTATUS from high (logic 1) then suddenly goes low (logic 0)?
- If the nSTATUS is low from the beginning right after power up, then even JTAG configuration with .sof file would failed.
- If the nSTATUS from high (logic 1) then suddenly goes low (logic 0) during middle configuration process, then either due bitstream corruption or power issue.
2.Have programmed .sof file via JTAG configuration ?
If the .sof file can be configure via JTAG successfully then the LED should blink. Thus it is not a power issue since JTAG configuration is successful. If the JTAG configuration with .sof file failed, thus it is a power issue.
Anand Raj Shankar
