13 years agoConcurrent writes in multi-ported memories
Hello, Do Altera FPGA s have a mechanism to handle concurrent writes? From what I could find from the documentation if both ports try write to same to the same address in the same clock cycle, ...
13 years ago --- Quote Start --- the author of the paper that I have attached has come up with techniques to build memories for FPGA having more ports using these dual ported memories as building blocks. I have done the same. All the ports operate at the same frequency. So now that I can build a nW/nR memory I was thinking about handling concurrent writes to same memory location. --- Quote End --- Keep in mind that page 43 of that paper has the statement: "we assume that multiple writes to the same address are prevented by the system using the multi-ported memory, and that the result of doing so is undefined" Why try to handle concurrent writes to the same memory location, when such writes make no sense? Can you provide a use-case of a system where two writes to the same location should be allowed (for a memory, not an I/O port)? As soon as you make the statement that a write on port A always wins, you have a priority for the multiplexing control. Just an observation ... Cheers, Dave
