13 years agoConcurrent writes in multi-ported memories
Hello, Do Altera FPGA s have a mechanism to handle concurrent writes? From what I could find from the documentation if both ports try write to same to the same address in the same clock cycle, ...
13 years agoHi,
If you simultaneously write to the same address of a dual-ported memory from both ports, the output port value is unknown in read/write clock mode. However, Altera 7014[/attach]https://www.alteraforum.com/forum/attachment.php?attachmentid=7015 ltera.com/literature/hb/stratix-v/stx5_51003.pdf"]embedded memory documentation (http://www.a[attach=) doesn't list any restrictions on the contents of the memory (at least I didn't see any in the documentation). Interestingly enough, Xilinx does have such a restriction described in a Conflict Avoidance section of its embedded memory documentation (http://www.xilinx.com/support/documentation/user_guides/ug383.pdf) on page 15. I'd assume there has to be such a restriction, unless Altera implemented some sophisticated mechanism to handle this case. Thanks, Evgeni
