16 years agocomunication Nios-Block diagramm
i have a Nios system which calculates several values (as long integer) now i wantto transfer them to a blockdiagramm somehow and multiplie them there or do some other aritmetics with them. What is the best way to get them from nios to the blockdiagramm? - over serial uart? how can i multiplie the values then? - over parallel io? do i have to build a multiplier then out of logic blocks? how do i output the 32bit value in nios then? or how is this normally done? thanks in advance..No RepliesBe the first to reply
