11 years agoComputing Argument of a Complex Number
I have a complex input, both I & Q are 16 bit wide signed integers, and I want to compute its argument. I have read several solutions, CORDIC, LUT based ATAN, and Altera ATAN function. The latter seems to consume a huge amount of resources, and it's using floating point to the best of my knowledge... I've eliminated this one. My questions are: 1) Should I convert to fixed point arithmetic? 2) What is the best (and fastest in terms of implementation) solution to use?5 Replies
Puts are always the quickest. The values can either be loaded from a file or computed in the hdl itself. It will have the lowest latency too. But depending on the accuracy requirements it can eat a lot of ram. Fixed point will always be better than floating because of its integer based arithmatic.
Please excuse my ignorance, but... what is "puts"? Or do you mean LUTs?
I've just read the documentation of this core: http://opencores.org/project,cordic It does exactly what I want, converting rectangular to polar... seems like I tend to use it. What do you think? - Altera_Forum
I meant puts. I was playing from my phone and got autocorrected.
I'd it does what you want, go for it. Don't expect much support for anything from open cores though. - Altera_Forum
Would you please explain more what do you mean by "puts"?
CORDIC is giving good results, but it takes several clock cycles to compute. - Altera_Forum
LUTS
Silly phone again
