14 years ago
Compressed Bit Stream (EP3C40F484C7)
I have been trying to program a Cyclone III (EP3C40F484C7) in Passive Serial mode, driven by a CPLD, using the RBF file. When I program the part with a compressed RBF file(1,289KB), the part programs as expected. This RBF file is created by selecting "generate compressed bitstream" in the configuration settings in Quartus. However if I program the part with an uncompressed RBF file(3,488KB) I never receive a done back from the part and it does not program.
Has anyone else encountered this issue?
What might be a reason for the bitstream requiring compression?
Thank you.
    actually you only need the compression if your program memory (flash EPCS group) is less than your program created.
    Simply adjusting the compression of.
    Thanks, but I am not programming a flash, I am programing the FPGA directly with the RBF file.
    Hi, cprillo
    Did you fix the problem of umcompressed RBF file? I have come to this problem too, on stratix II fpga.
