15 years agoComponents in Verilog vs. VHDL
Hi, here is an instance from a scfifo in verilog scfifo the_user_to_master_fifo ( .aclr (reset), .clock (clk), .data (user_buffer_data), .full (u...
15 years agoThanks for your reply,
Great idea with the function. I now have written the function:function fifo_use_eab ( use_eab : boolean ) return string is
begin
if (use_eab = true) then
return "ON";
else
return "OFF";
end if ;
end function fifo_use_eab;Now i can use the function as "actual" in the generic map during the component instantiation in my code. scfifo_component : scfifo
generic map
add_ram_output_register => "OFF",
intended_device_family => "Cyclone III",
lpm_numwords => fifo_depth,
lpm_showahead => "ON",
lpm_type => "scfifo",
lpm_width => 8,
lpm_widthu => fifo_depth_log2,
overflow_checking => "ON",
underflow_checking => "ON",
use_eab => fifo_use_eab (fifo_use_memory)
port map
clock => clock,
sclr => sclr,
wrreq => wrreq,
aclr => aclr,
data => data,
rdreq => rdreq,
usedw => usedw,
empty => empty,
full => full,
q => q
);That is quiet the thing.
