15 years agoComponents in Verilog vs. VHDL
Hi, here is an instance from a scfifo in verilog scfifo the_user_to_master_fifo ( .aclr (reset), .clock (clk), .data (user_buffer_data), .full (u...
15 years agoI too have longed for such a 'ternary' statement in VHDL for a long time. Until it dawned upon me that I could write a function to achieve the effect. Here is one of my functions:
function ternary( f , s : integer ; condition : string ; tr , fr : string )
return string
is
begin
if (condition = "EQ" ) then
if ( f = s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "GT") then
if ( f > s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "GTE") then
if ( f >= s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "LT") then
if ( f < s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "LTE") then
if ( f <= s ) then
return tr ;
else
return fr ;
end if ;
end if ;
end function ternary ;
In your case you would use this as follows :
use_eab => ternary( FIFOUSEMEMORY , 1 , "EQ" , "ON" , "OFF") , May look a bit contrived, but it works! VHDL handles 'overloading' so I wrote a few variants of the 'ternary' function to cover for other input parameters and return values.
