15 years ago
Components in Verilog vs. VHDL
here is an instance from a scfifo in verilog
scfifo the_user_to_master_fifo (
.aclr (reset),
.clock (clk),
.data (user_buffer_data),
.full (user_buffer_full),
.empty (user_buffer_empty),
.q (master_writedata),
.rdreq (read_fifo),
.wrreq (user_write_buffer)
defparam the_user_to_master_fifo.lpm_width = DATAWIDTH;
defparam the_user_to_master_fifo.lpm_numwords = FIFODEPTH;
defparam the_user_to_master_fifo.lpm_showahead = "ON";
defparam the_user_to_master_fifo.use_eab = (fifousememory == 1)? "on" : "off";
defparam the_user_to_master_fifo.add_ram_output_register = "OFF";
defparam the_user_to_master_fifo.underflow_checking = "OFF";
defparam the_user_to_master_fifo.overflow_checking = "OFF";
and here in VHDL:
scfifo_component : scfifo
GENERIC MAP (
add_ram_output_register => "OFF",
intended_device_family => "Cyclone III",
lpm_numwords => fifo_depth,
lpm_showahead => "ON",
lpm_type => "scfifo",
lpm_width => 8,
lpm_widthu => fifo_depth_log2,
overflow_checking => "ON",
underflow_checking => "ON",
use_eab => "on"
PORT MAP (
clock => clock,
sclr => sclr,
wrreq => wrreq,
aclr => aclr,
data => data,
rdreq => rdreq,
usedw => sub_wire0,
empty => sub_wire1,
full => sub_wire2,
q => sub_wire3
Now my question:
Can i use conditional signal assignments for "actuals" in generic maps in VHDL like
in Verilog ?
I have tried
use_eab => ("0n" when (fifo_use_memory = 1) else "off")
but this doesent work.
Nicolas
    Thanks for your reply,
    Great idea with the function. I now have written the function:
    function fifo_use_eab ( use_eab : boolean ) return string is
    begin
        if (use_eab = true) then
            return "ON";
        else
            return "OFF";
        end if ;
    end function fifo_use_eab;
    Now i can use the function as "actual" in the generic map during the component instantiation in my code.
    generic map
            lpm_width => 8,
            use_eab => fifo_use_eab (fifo_use_memory)
    port map
            clock => clock,
            sclr => sclr,
            wrreq => wrreq,
            aclr => aclr,
            data => data,
            rdreq => rdreq,
            usedw => usedw,
            empty => empty,
            full => full,
            q => q
    That is quiet the thing.
    I too have longed for such a 'ternary' statement in VHDL for a long time. Until it dawned upon me that I could write a function to achieve the effect. Here is one of my functions:
    	function ternary( f , s : integer ; condition : string ; tr , fr : string )
    		return string
    		is
    		begin
    			if (condition = "EQ" ) then
    				if ( f = s ) then
    					return tr ;
    				else
    					return fr ;
    				end if ;
    			elsif (condition = "GT") then
    				if ( f > s ) then
    					return tr ;
    				else
    					return fr ;
    				end if ;
    			elsif (condition = "GTE") then
    				if ( f >= s ) then
    					return tr ;
    				else
    					return fr ;
    				end if ;
    			elsif (condition = "LT") then
    				if ( f < s ) then
    					return tr ;
    				else
    					return fr ;
    				end if ;
    			elsif (condition = "LTE") then
    				if ( f <= s ) then
    					return tr ;
    				else
    					return fr ;
    				end if ;
    			end if ;
    		end function ternary ;
    In your case you would use this as follows :
    use_eab => ternary( FIFOUSEMEMORY , 1 , "EQ" , "ON" , "OFF") ,
    May look a bit contrived, but it works!
    VHDL handles 'overloading' so I wrote a few variants of the 'ternary' function to cover for other input parameters and return values.
