14 years agoComponent is outside master's address range
Hi, I have 2 Avalon MM Master components and 1 Avalon MM Slave. If I connect them together - to one slave I get error:
Error: System.stream2eth.avalon_master: DM9000A.s1 (0x11048..0x1104b) is...
14 years agoHello Everyone,
In order to get the solution of this type errors,Master port must have 32-bit width,and use byte enable signal for how many byes you want to use. Previously i got the same error,after that i got the solution from the same forum. -Vasireddyrajesh3.
