12 years agoComponent Declaration
Hey people, I have a simple question that I can't find an answer to on the web. I have a code for a simple vga test which is split in three sections. I can't figure out a way to connect the three of ...
12 years agoYou can use separate files. I usually have separate files for all entities and packages.
Next you tell Quartus which is your top-level entity (right click on file in project navigator, or via settings). If your code is correct it should compile. But are you getting any errors that you ask how this works?
