14 years agocompiling error
I have the following error when compiling with quartus II 32-bit version 1.1 build 216 11/23/2011.
Error (10327): VHDL error at test_pld.VHD(354): can't determine definition of operator ""+"" -- found 0 possible definitions The code is below U9: process(serialclk, data, count_b)--74HC590 begin if (data = '0') then count_b <= "00000"; elsif (serialclk'event and serialclk = '1') then count_b <= count_b + 1; << this is where the compiler error. end if; end process;4 Replies
I did exactly what Bertulus suggested and it works.
Thanks you all. - Altera_Forum
--- Quote Start --- You are mixing types. VHDL cares about the type (integer/vector). Try: count_b <= count_b + '1'; It should fix it. --- Quote End --- that wont work with standard VHDL, assuming count_b is a std_logic_vector, because you cannot do arithmatic with std_logic_vectors. You need to include the numeric_std library and make count_b an unsigned, as bertulus suggested to make the origional code work. But this is all speculation, because we havent seen all of the OPs code. - Altera_Forum
Try: count_b <= count_b + '1'; It should fix it. - Altera_Forum
You didn't post the declaration of the vector count_b, but I guess:
signal count_b : std_logic_vector(4 downto 0); you can't add vector of type "std_logic_vector" ( width some library you can do it, but isn't a good practice ). The to do it is: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity..... architecture... signal count_b : unsigned(4 downto 0); process... count_b <= count_b + 1; If you need count_b as a std_logic_vector type you may cast it: count_2 <= std_logic_vector(count_b); ( count_2 is an arbitrary name )
