14 years agocompiling error
I have the following error when compiling with quartus II 32-bit version 1.1 build 216 11/23/2011. Error (10327): VHDL error at test_pld.VHD(354): can't determine definition of operator ""+"...
14 years agoYou didn't post the declaration of the vector count_b, but I guess:
signal count_b : std_logic_vector(4 downto 0); you can't add vector of type "std_logic_vector" ( width some library you can do it, but isn't a good practice ). The to do it is: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity..... architecture... signal count_b : unsigned(4 downto 0); process... count_b <= count_b + 1; If you need count_b as a std_logic_vector type you may cast it: count_2 <= std_logic_vector(count_b); ( count_2 is an arbitrary name )
