8 years ago
Compile error 169025 Too many I/O pins assigned in I/O bank
My design is based on a FPGA online course I'm taking through Coursesea
I'm seeing a conflict between the compile error and the pin planner
I'm using Quartus 16.1 lite (free), processor MAX10 10M08DAF484C8GES
I did research the forum for help, no luck. I'm also the Max10 datasheets
compile error states 37 pins assigned in I/O bank 8 only 36 I/O pins allowed
versus
pin planner shows 33 pins assigned and 3 pins available, see IO Bank Usage attachment
Per the instructor direction I assigned the pins from a combination of
- pin planner:
  • 2 single pins dropped
  • dropping grouped bus pins into the bank#
- using the pin Assignment Edito:
  • other single pins.
OMG I just discovered copying / pasting the compile error below I get the signals i placed in bank 8 plus there's 3 ~signals that i didn't place but this only adds up to 36 pins not 37.
- So what is the 37th pin?
- why did these signals get placed? One confession I did do a back annotate before re-assigning the pins.
Info (169112): Pin ~ALTERA_CONFIG_SEL~ Info (169112): Pin ~ALTERA_nCONFIG~
Info (169112): Pin ~ALTERA_nSTATUS~
Error (169025): Too many I/O pins (37) assigned in I/O bank 8 - no more than 36 I/O pins are allowed in the I/O bank
Info (169112): Pin A[31]
Info (169112): Pin A[30]
Info (169112): Pin A[28]
Info (169112): Pin A[26]
Info (169112): Pin A[24]
Info (169112): Pin A[22]
Info (169112): Pin A[20]
Info (169112): Pin A[18]
Info (169112): Pin A[16]
Info (169112): Pin A[14]
Info (169112): Pin A[12]
Info (169112): Pin A[10]
Info (169112): Pin A[8]
Info (169112): Pin A[6]
Info (169112): Pin A[4]
Info (169112): Pin A[2]
Info (169112): Pin A[0]
Info (169112): Pin A[1]
Info (169112): Pin A[3]
Info (169112): Pin A[5]
Info (169112): Pin A[7]
Info (169112): Pin A[9]
Info (169112): Pin A[11]
Info (169112): Pin A[13]
Info (169112): Pin A[15]
Info (169112): Pin A[17]
Info (169112): Pin A[19]
Info (169112): Pin A[21]
Info (169112): Pin A[23]
Info (169112): Pin A[25]
Info (169112): Pin A[27]
Info (169112): Pin A[29]
Info (169112): Pin reset_n
