10 years agocomparing arria10 and stratix v fmax for same design
hi, i have a RTL design which I map to arrai10 and stratix V fpgas. i synthesize the design in synplify_premier for arria10 and stratixV (using the exact same synth settings) and transfer the...
10 years agoHave you tried using Quartus to synthesize your source code, rather than running it through Synplify? I would certainly expect higher Fmax values for Arria 10 over Stratix V.
What speed grade devices are you using from each family for your test? Having asked those questions - I've just run one of my reference designs (rtl only, no PLLs or other Altera IP) through each family, selecting -2 speed grade in each case. I find the Fmax in each case surprisingly similar, and broadly in line with your findings - Stratix V is reportedly about 0.05% quicker... I think have a need to try that again with another design... Cheers, Alex
