17 years agocommunicatiom between external board running CDR and FPGA
hi all
i need your help please. communication between external board running CDR and FPGA I am working in connecting Startix Gx 'EP1SGX40GF1020C5' FPGA with external board . the board Receive optical signal carrying information at 125 Mbps . and it convert this signal using CDR to tow line one for data 125 Mbps and the other for clock 125 MHZ. i need to connect the tow line data and clock to the FPGA using SMA connectors. could you please give me suggestion how can i solve this problem. which type of protocol good to use in side the FPGA . what i have to do if i want to connect directly the optical signal to the FPGA without sing the borad. Thank you11 Replies
Have you thought of using serdes, it contains an internal FPGA CDR circuitry. Check if it accepts your 125Mbps. If not you will need to upsample it.
