16 years agocommunicatiom between external board running CDR and FPGA
hi all
i need your help please. communication between external board running CDR and FPGA I am working in connecting Startix Gx 'EP1SGX40GF1020C5' FPGA with external board . the board Receive optical signal carrying information at 125 Mbps . and it convert this signal using CDR to tow line one for data 125 Mbps and the other for clock 125 MHZ. i need to connect the tow line data and clock to the FPGA using SMA connectors. could you please give me suggestion how can i solve this problem. which type of protocol good to use in side the FPGA . what i have to do if i want to connect directly the optical signal to the FPGA without sing the borad. Thank you
