17 years agocommunicatiom between external board running CDR and FPGA
hi all i need your help please. communication between external board running CDR and FPGA I am working in connecting Startix Gx 'EP1SGX40GF1020C5' FPGA with external board . the board...
17 years agoYou go to megawizard and instantiate it(select the component from the list, possibly called altlvds). then follow the GUI.
this example may help(was used in stratix ii): input: video data upsampled
ENTITY serdes_rx_core IS
PORT(
rx_in : IN STD_LOGIC; --819.2Mbps
rx_inclock : IN STD_LOGIC; -- 40.96MHz clk for pll
rx_dpa_locked : OUT STD_LOGIC;
rx_locked : OUT STD_LOGIC ;
rx_out : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);-- 16:1
rx_outclock : OUT STD_LOGIC -- parallel data clk
END serdes_rx_core; Above serdes has internal PLL that uses 40.96MHz as reference(other figures possible), then generates 51.2MHz data clk
