17 years agocommunicatiom between external board running CDR and FPGA
hi all i need your help please. communication between external board running CDR and FPGA I am working in connecting Startix Gx 'EP1SGX40GF1020C5' FPGA with external board . the board...
17 years ago --- Quote Start --- Actually, I don't see a way to use GX transceiver for lower data rates by upsampling, particularly regarding CDR operation. CDR can be imagined as a PLL locking on the serial input edges, in can't tolerate additional edges introduced by upsampling. User CDR designs are mostly all digital PLL, involving oversampling of the input data stream by a sufficient factor, e.g. factor 4 as used in full speed USB. It seems still feasible for 125 Mbps in Stratix devices, particularly if DDIO or possibly SERDES circuits are utilized. Another user CDR option is provided by PLLs with dynamic phase shifting option, as present in newer devices starting with Cyclone III, Stratix III and Arria II. --- Quote End --- Additional edge will have to be synchronised to data clk. The external upsampler will have to stuff on a faster synchronised clk. As to serdes reference clk, that is going to be listed in serdes setup. You enter your bit rate and serilisation factor, then quartus tells you what clks can be used as reference for internal PLL of serdes.
