11 years agocommunicating with Ethernet port and PC using altera cyclone iv transceiver kit
I would like to transfer data from the Ethernet port to the PC using a LAN cable using the altera cyclone iv transceiver starter kit . Can anyone suggest how as to how I can proceed?2 Replies
You may also contact your local FAE to arrange for a demo.
Probably you could did a quick search into the Altera wiki to see if can find any triple speed ethernet IP design targeting CIV device. You can check also if the design uses the starter kit for verification.
