Jacob11's avatar
Jacob11
4 years ago
Command Line compile causing issue with Quartus Standard vs Quartus Prime Pro
Hello support team. I am developing for the MAX10 FPGA, which is being used as a management/controller system for a Stratix 10 device on the same board. Naturally, I have both Quartus Standard and...
  • sstrell's avatar
    4 years ago
    That's very odd. After you compile from the command line, what directories appear in the project folder? For a Standard compile, you should see db and incremental_db. In Pro, you would see qdb.
    If you delete whichever of these directories you see, can you then open the project in the Standard GUI?
