14 years agoCommand FPGA using Matlab
I would like to know how to command my FPGA board with Matlab. I explain : I would like for exemple switch on a LED with Matlab and RS232 connexion. I don't know how to make it... If I have to use UART with TX and RX or if they are some function in Matlab. My FPGA is ep2c35f672c6n and I use matlab r2007b. Thanks for your help :)4 Replies
I have implemented niosII on my fpga with the uart and serial device. I have made a C program in order to send Hello World on serial port and it's successful.
With this code my FPGA send "hello world" to my computer. But now I would like to send information on my FPGA with serial port in order to control my FPGA. I explain: If I send '1' from my computer to the FPGA I would like that the LEDG(1) turn on. If I send '2' the LEDG(2) turn on... I don't know how to make it... I know that I have to take the information on RX but I don't know how to do it#define RS232_UART_DATA ((volatile int*) 0x10001010) # define RS232_UART_CONTROL ((volatile int*) (0x10001010+4)) int main() { unsigned char hwld = {'H','e','l','l','o',' ','W','o','r','l','d','\0'}; unsigned char *pOutput; pOutput = hwld; while(*pOutput) //strings in C are zero terminated { //if room in output buffer if((*RS232_UART_CONTROL)&0xffff0000 ) { //then write the next character *RS232_UART_DATA = (*pOutput++); } } } - Altera_Forum
--- Quote Start --- Yes I can use SOPC an QSYS features with QII --- Quote End --- That's good. --- Quote Start --- Yes I have knowledges in VHDL, but not in verylog --- Quote End --- That's good either. --- Quote Start --- But I don't know how to use SOPC. I have to place all component (UART and serail device)? --- Quote End --- If you wish to extend your commanding by MATLAB in the future, is suggest that you implement a NIOSIIe (the simplest) and a UART-Peripheral. I recommend QSYS, because it (has already) superseded SOPC. I'm not sure if ALTERA is provide a GPIO-Peripheral. This could be used to drive the LED-Pin. You'll have to to create a QSYS-system with NIOSIIe: Instruction Avalon Master -> On-Chip RAM that holds you code NIOSIIe: Data Avalon Master -> GPIO-Peripheral Avalon Slave NIOSIIe: Data Avalon Master -> UART-Peripheral Avalon Slave After you've successfull described you system and build it, you'll have to instantiate it in a top-level (V)HDL Wrapper (or BSF) in QII. After that worked you'll have to write your NIOSII-SW based on the Board-Support-Package QSYS created for you. I guess that will be no simple task. Do you need to control the board directly via MATLAB or is a command window sufficient? That would generate significant less work in the FPGA, because you could exclude the NIOS and the SW part. In that case you'll have to to create a QSYS-system with JTAG-UART-Peripheral Avalon Master -> GPIO-Peripheral Avalon Slave After you've successfull described you system and build it, you'll have to instantiate it in a top-level (V)HDL Wrapper (or BSF) in QII. You could split your task in two phases: 1. Implemented the JTAG-UART based solution (gaining QSYS basic knowledge and establish a commanding interface to the PC) 2. Implement the NIOSIIe based solution (developing the sophisticated solution based on the knowledge gained in 1.) - Altera_Forum
Yes I have knowledges in VHDL, but not in verylog But I don't know how to use SOPC. I have to place all component (UART and serail device)? And yes with Matlab we can transmit data but i don't know how to do it but I'll find :) - Altera_Forum
Do you have a QII subscription edition respective a license with allows you to use the SOPC/QSYS feature?
Do you have any HDL background? In any case you've to implement logic into the FPGA that understands serial data received from the UART and translates that into a high respective low on the aproppriate FPGA pin that is connected to you LED. My MATLAB knowledge is very poor. Is MATLAB able to transmit data (i.e. characters) over a console/UART?
