14 years agoCommand FPGA using Matlab
Hi, I would like to know how to command my FPGA board with Matlab. I explain : I would like for exemple switch on a LED with Matlab and RS232 connexion. I don't know how to make it... If I...
14 years agoDo you have a QII subscription edition respective a license with allows you to use the SOPC/QSYS feature?
Do you have any HDL background? In any case you've to implement logic into the FPGA that understands serial data received from the UART and translates that into a high respective low on the aproppriate FPGA pin that is connected to you LED. My MATLAB knowledge is very poor. Is MATLAB able to transmit data (i.e. characters) over a console/UART?
