14 years agoCommand FPGA using Matlab
Hi, I would like to know how to command my FPGA board with Matlab. I explain : I would like for exemple switch on a LED with Matlab and RS232 connexion. I don't know how to make it... If I...
14 years ago --- Quote Start --- Yes I can use SOPC an QSYS features with QII --- Quote End --- That's good. --- Quote Start --- Yes I have knowledges in VHDL, but not in verylog --- Quote End --- That's good either. --- Quote Start --- But I don't know how to use SOPC. I have to place all component (UART and serail device)? --- Quote End --- If you wish to extend your commanding by MATLAB in the future, is suggest that you implement a NIOSIIe (the simplest) and a UART-Peripheral. I recommend QSYS, because it (has already) superseded SOPC. I'm not sure if ALTERA is provide a GPIO-Peripheral. This could be used to drive the LED-Pin. You'll have to to create a QSYS-system with NIOSIIe: Instruction Avalon Master -> On-Chip RAM that holds you code NIOSIIe: Data Avalon Master -> GPIO-Peripheral Avalon Slave NIOSIIe: Data Avalon Master -> UART-Peripheral Avalon Slave After you've successfull described you system and build it, you'll have to instantiate it in a top-level (V)HDL Wrapper (or BSF) in QII. After that worked you'll have to write your NIOSII-SW based on the Board-Support-Package QSYS created for you. I guess that will be no simple task. Do you need to control the board directly via MATLAB or is a command window sufficient? That would generate significant less work in the FPGA, because you could exclude the NIOS and the SW part. In that case you'll have to to create a QSYS-system with JTAG-UART-Peripheral Avalon Master -> GPIO-Peripheral Avalon Slave After you've successfull described you system and build it, you'll have to instantiate it in a top-level (V)HDL Wrapper (or BSF) in QII. You could split your task in two phases: 1. Implemented the JTAG-UART based solution (gaining QSYS basic knowledge and establish a commanding interface to the PC) 2. Implement the NIOSIIe based solution (developing the sophisticated solution based on the knowledge gained in 1.)
