14 years agoCode verilog has an error
Hi everybody!
I have a code, I write it to control for 7 segment. but I did't understand that an error appearing. I repaired for many times. But cannot .............. I'm confuse. module led (clkin_50,cpu_resetn, seven_seg_sel[1], seven_seg_sel[2], seven_seg_sel[3], seven_seg_sel[4], seven_seg_a, seven_seg_b, seven_seg_c, seven_seg_d, seven_seg_e, seven_seg_f, seven_seg_g, seven_seg_dp ); input clkin_50, cpu_resetn; reg [3:0] state; reg [6:0] number; output seven_seg_sel[1],seven_seg_sel[2],seven_seg_sel[3],seven_seg_sel[4],seven_seg_a,seven_seg_b,seven_seg_c,seven_seg_d,seven_seg_e,seven_seg_f,seven_seg_g,seven_seg_dp; parameter number4 = 7'b1001100; assign {seven_seg_sel[4],seven_seg_sel[3],seven_seg_sel[2], seven_seg_sel[1]} = state; assign{seven_seg_a,seven_seg_b,seven_seg_c,seven_seg_d,seven_seg_e,seven_seg_f,seven_seg_g} = number; assign seven_seg_dp = 1; always @ (posedge clkin_50) if (cpu_resetn == 0) state <= 4'b0000; else state <= 4'b0001; always @ (posedge clkin_50) if (cpu_resetn == 0) number <= 7'h7f; else number <= number4; endmodule I attached a photo which I took photograph. Any help I really thanks and wait.........4 Replies
do you have any other method for this?
[NG]
output seven_seg_sel[1]; [OK] output [1]seven_seg_sel; - Altera_Forum
Unpack array types error: You don't have to declare and assign the seven_seg_sel one by one.
answer for: on left-hand side of assignment must have a net type (http://goo.gl/pxkw6)
keyword: wire.
