Aravindpb's avatar
Aravindpb
5 years ago
code flash error in 5cgxfc7c6f23
hai!...
I am using 5CGXFC7C6F23 IC, during code flash into controller, programmer setup showing some error like couldnt connect the device. we are using usb blaster 2 programmer ( driver installed )and programmer ide ver: 14.0. During fpga board power down mode as well as power on mode same problem is coming. kindly give your valuable solution and i have attached the error message image for your reference.
Thanks &regards
Aravind P
  • Alberto_Sykes's avatar
    Alberto_Sykes
    Aravindpalanisamy, Thank you very much for your response.
    Let me apologize for any inconvenience, I already transferred the case to the proper department before, I will transfer it once again for them to further assist you as soon as possible.
    Albert R.
    Intel Customer Support Technician
    Alberto_Sykes
    Aravindpalanisamy, Thank you for posting in the Intel® Communities Support.
    In reference to this scenario, just to let you know, I moved your post to the proper department so they can further assist you with this matter as soon as possible.
    Albert R.
    • Aravindpb's avatar
      Aravindpb
      Hai Alberto_r_intel!!.
      Last 4 days i am waiting for the reply for my above question but still not received any assistance form your side . Kindly take it as a high priority and suggest me as soon as possible.
