JFK
4 years agoClocks for 10M08SAU169C8G ADC's core
Hi,,
I'm using the MAX 10 10M08SAU169C8G in a new design. The documentation on the ADC (core only) is not clear. to me.
Would someone tell me what peripheral clock frequency is required when ...
Farabi_Altera
4 years agoHi,
The peripheral clock only used when you cant occupy PLL clk that connected to feed ADC clock. By default, MAX10 will use dedicated clock which is coming from the PLL, and the default frequency is 10Mhz.
If you want 1us interval sampling data, 10Mhz dedicated clock from PLL to ADC clock is sufficient.
regards,
Farabi
JFK
4 years agoHi Farabi,
Sorry to belabor this subject but I'm still confused. The ADC hard IP core takes two clocks and one is the 10MHz input on c0 from PLL1.
What do I connect the peripheral clock input to?
See attachment.
