14 years agoClock synchronization across 1Msps ADCs
Hi, I'm hoping some of you might prod me in the right direction. I'm looking to synchronize a large number of ADC channels going into an FPGA. The sampling rate is high (~1MSPS), but doesn't ...
14 years ago --- Quote Start --- I'm looking at fairly high dynamic range (16-24 bits, differential inputs), but more important than dynamic range is phase matching across channels. --- Quote End --- The dynamic range of your signal will be limited by the clock jitter. The limit on the jitter can be estimated from the amplitude error you get when sampling a sinusoid with a clock that has jitter. Take a look in the data conversion handbook, edited by Walt Kester (newnes, 2005), p2.71 and p2.72 http://www.analog.com/library/analogdialogue/archives/39-06/data_conversion_handbook.html and p17 http://www.ovro.caltech.edu/~dwh/carma_board/digitizer_tests.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/digitizer_tests.pdf) An ideal 16-bit converter an SNR_Q of about 6dB x 16 = 96dB, whereas a 24-bit converter has an SNR_Q of about 6dB x 24 = 144dB. Look at the plot on p2.72 of Kester, at your 1MHz sampling rate, your jitter needs to be lower than 1ns for 16-bit operation and lower than a few 10s of femtoseconds for higher resolution. Your design difficulty will be in achieving low jitter. So, determine if that really is a requirement first. Cheers, Dave
