18 years agoClock skews, enables and timing
Can someone help me? I am new to this and have been learning from scratch to program FPGAS and windows at the same time whilst building hardware. I have written some code for a data capture s...
18 years ago --- Quote Start --- When I look at the compile window it gives me errors such as gated clocks causing skew... Someone mentioned on here that I need to use chip enable clocks to sort out the gated clock issue but I do not know how to do this? could someone give me some pointers in verilog? --- Quote End --- See http://www.alteraforum.com/forum/showthread.php?t=2388. That thread goes into detail about design recommendations for gated clocks. One of the posts talks about clock enables and has a reference to the Quartus text editor templates showing the proper way to code for clock enables.
