11 years agoclock select for internal FPGA logic
HI I am working on Arria v FPGA and I am writing the code for transferring serial data to a remote module using RS-422 protocol. Here I need to dynamically change the clock rate depending on some...
11 years agoNot using available UART modules is certainly the hard way to do it. You should look at the PLL re-configuration feature. It would be more flexible and probably use less resources than what you've outlined.
