Clock recovery from signle 125MHz pulses with PLL
I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity of data and clock recovery). From this data there are recovered 125 MHz pulses every 44.1 kHz (sync pulses). I would like to recover this 44.1 kHz clock from the bit stream. (for audio purposes - to match the clock of the data - if internal 44.1 clock is used form the generator there are some bad effects in the sound). My questions are: 1) Can i simply feed those pulses into the second PLL module to recover the data ? 2) Are there any other considerations that i should think about ? thanks madness12325 Replies
The sophisticated functionality offered with the NCO core is the resource saving way to generate high resolution sine waves. A basic digital NCO as required for a ADPLL isn't more than a simple phase accumulator, involving a few lines of HDL code. The method is explained in the NCO user manual. Also low and medium resolution sine generators can be easily implemented without referring to the Altera core if you don't have a Quartus subscription license.
thanks FvM, best regards madness - Altera_Forum
I opened megafunction wizard and found NCO. Are there any restrictions to using this megafunction ?
--- Quote Start --- Yes you need to pay a license for it, or use it in evaluation mode (i.e. with the USB blaster connected all the time, and you can't flash your project) --- Quote End --- So as long as your USB-Blaster is connected, you can play with it. best regards - Altera_Forum
yes. You'll see a window after you configure the FPGA saying you are in evaluation mode. Don't close this window and you can use the NCO. It will stop working when you close the window, or after a certain delay (1 hours IIRC) if you disconnect the USB blaster.
