14 years ago
Clock problem
Hi All,
I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my code. I can not assign a new clock frequency to an output variable which I wanted to assign to an output pin.
I am getting the following error for my code which is shown below:
Error (10517): VHDL type mismatch error at clock.vhd(23): std_logic_vector type does not match integer literal
My Code:
-- Divide clock frequency by 2
-- Standard libary delarations
library ieee;
use ieee.std_logic_1164.all;
-- define input and outputs for the entity
entity clock is port(
clk_in: in std_logic;
clk_out: buffer std_logic;
va: buffer std_logic_vector(2 downto 0) );
end clock;
-- internal function of enetity
architecture behave of clock is
--internal variable
signal count : integer :=1;
begin
process (clk_in,clk_out,va)
begin
-- Required in order to convert the sinewave to a square wave
clk_out <= not clk_in;
-- Check for rising edge of clock
if(clk_out'event and clk_out='1') then
--increment the count variable by 1
count <=count+1;
-- when count is 2
if(count = 2) then
--assign 1 to the variable which will be assigned to an output pin
va <= 1;
end if;
end if;
end process;
end behave;
Thank you in advance.
    Gated clocks are bad.
    but anyway, what's the point of using signal va as std_logic_vector? You're assigning one bit value to 3bit bus. Also the code logically won't work, since You don't reset the counter.
    I can't understand what you are trying to do.
    From your first sentence I assumed you want clk_out to be half the frequency of clk_in.
    This can be done with simple code, like this:
    if(clk_in'event and clk_in='1') then
    clk_out <= not clk_out;
    end if;
    Regarding the error. that's normal if you write va <= 1
    You defined va as a std_logic vector 3 bits long, so you must use va <= "000"
    Anyway, your code seems to be useless since va is not initialized to any other value
    and assigned only to 1 when count is 2.
    I'd expect at least a reset signal, in order to reset count and va to initial status.
