14 years agoClock problem
Hi All, I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my c...
14 years agoGated clocks are bad.
but anyway, what's the point of using signal va as std_logic_vector? You're assigning one bit value to 3bit bus. Also the code logically won't work, since You don't reset the counter.
