14 years ago
Clock problem
Hi All,
I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my code. I can not assign a new clock frequency to an output variable which I wanted to assign to an output pin.
I am getting the following error for my code which is shown below:
Error (10517): VHDL type mismatch error at clock.vhd(23): std_logic_vector type does not match integer literal
My Code:
-- Divide clock frequency by 2
-- Standard libary delarations
library ieee;
use ieee.std_logic_1164.all;
-- define input and outputs for the entity
entity clock is port(
clk_in: in std_logic;
clk_out: buffer std_logic;
va: buffer std_logic_vector(2 downto 0) );
end clock;
-- internal function of enetity
architecture behave of clock is
--internal variable
signal count : integer :=1;
begin
process (clk_in,clk_out,va)
begin
-- Required in order to convert the sinewave to a square wave
clk_out <= not clk_in;
-- Check for rising edge of clock
if(clk_out'event and clk_out='1') then
--increment the count variable by 1
count <=count+1;
-- when count is 2
if(count = 2) then
--assign 1 to the variable which will be assigned to an output pin
va <= 1;
end if;
end if;
end process;
end behave;
Thank you in advance.
    sir your code is not working
    Error (10482): VHDL error at clk200.vhd(2): object "std_logic" is used but not declared
    --- Quote Start ---
    --- Quote End ---
    You still need to put in at the top: library ieee; use ieee.std_logic_1164.all
    In regard to this discussion, I'm surprised no one mentioned it, but I'd really design this as a module with 2 free-running counters that trigger each other; one to generate the "start" pulse at 1 Hz, and the other to generate the "long" pulse. Thinking of these as clocks just isn't a good idea.
