10 years agoClock out from GX Transciever
I'm planning on sending two lanes of JESD204B data down a QSFP cable. By my understanding this should be quite possible as there are four CML lanes in one direction which is enough for the two data lanes, and the devclk/sysref signals.
On the dev kit I am using (Stratix V GS DSP Development Kit) there is a QSFP connector which is wired up directly to the high speed transceivers of the FPGA, which means I need to use those to output the JESD data (easy) but also the devclk/sysref. I am aware that I can use on of the transceivers as a clock input, but I am curious if I can use them as clock outputs. I couldn't find anywhere that specifically states this is possible. I think it should be, after all a clock is basically just alternating data. Would it just be a case of feeding out the clock signal from the top level of the design and assigning it to the transceiver pins? Or would I need to instantiate high speed transceivers to send out the clock? I tried the first option (just assigning to transceiver pins), but as expected, this didn't work - the fitter gave the following error: --- Quote Start --- Error (184016): There were not enough differential output pin locations available (1 location affected) --- Quote End ---2 Replies
Surely somebody has needed to do this?
Never tried it, but it might be possible if you pick the transceiver that has the CMU PLL in it (if the Stratix V transceiver architecture at all resembles the Cyclone V architecture). Otherwise you'd end up having to generate a custom high speed transceiver to output the clock, which again should be possible, but much more of a pain.
