10 years agoClock out from GX Transciever
I'm planning on sending two lanes of JESD204B data down a QSFP cable. By my understanding this should be quite possible as there are four CML lanes in one direction which is enough for the two data l...
10 years agoNever tried it, but it might be possible if you pick the transceiver that has the CMU PLL in it (if the Stratix V transceiver architecture at all resembles the Cyclone V architecture). Otherwise you'd end up having to generate a custom high speed transceiver to output the clock, which again should be possible, but much more of a pain.
