8 years agoclock newtork delay and intradomain skew
Hi, I have a flip flop in my fpga which is driving output pins (reg to output path). The clock of this is 5ns and the one outside fpga is 5ns (phase shifted by 90). The phase shifted clock is g...
8 years agoI'm still a little confused. If a PLL in the FPGA is generating both of these clocks, your .sdc should look something like this:
# internal clock that drives the output register create_generated_clock -name output_clk -source <PLL_input_clock_pin> <relation_to_source> <PLL_output_clock_pin_1> # output clock to drive downstream device create_generated_clock -name emif_clk_int -source <PLL_input_clock_pin> <relation_to_source> -phase 90 <PLL_output_clock_pin_2> # extra generated clock to define clock coming out of FPGA going to downstream device create_generated_clock -name emif_clk -source <PLL_output_clock_pin_2> -multiply_by 1 <FPGA_clock_output_port> # false path so data analysis is not performed on output clock set_false_path -to <FPGA_clock_output_port> # output delays; you need to have separate max and min delays set_output_delay -max -clock emif_clk 4.5 [get_ports LC0] set_output_delay -min -clock emif_clk <min_value> [get_ports LC0] set_output_delay -max -clock emif_clk 4.5 [get_ports LC1] set_output_delay -min -clock emif_clk <min_value> [get_ports LC1] set_output_delay -max -clock emif_clk 4.5 [get_ports LC2] set_output_delay -min -clock emif_clk <min_value> [get_ports LC2] # multicycle so correct latch edge is used set_multicycle_path -from output_clk -to emif_clk -end -setup 2 Let me know if this matches your design, which is still unclear.
