clock multiplexing
It is recommended to use dedicated hardware to perform clock multiplexing when it is available, instead of using multiplexing logic. For example, you can use the clock-switchover feature or clock control block available. These dedicated hardware blocks ensure that you use global low-skew routing lines and avoid any possible hold time problems on the device due to logic delay on the clock line.
- BAro06 years ago
Thanks YY. I understand that it is recommended to use dedicated blocks. Unfortunately I need to multiplex a clock signal coming from a non dedicated external pin so I cannot use the dedicated block. My question is if it is safe to use a logic multiplexer to do so. Please note that I do not intend to switch the multiplexer input when the clock is enabled.
