16 years agoClock group vs. clock false path
I have a couple of clocks coming in that are not related to each other. Before I put them in a group, I ran TimeQuest and it was complaining about some setup slack violation. I know I should have u...
16 years agokaz, that makes a lot of sense. funny you mention it, I have a reset signal that changes very rarely that is also causing some timing issues. A false path there should solve that issue - the reset signal is valid for multiple cycles of the slowest clock.
rbugalho, I have a number of clocks in the system and no matter what they are (even 1:1 plls), I don't trust their relationships and I either double flop or use dcfifo for CDC. Would I still be lying to TimeQuest if I put all those clocks in groups?
