17 years ago
clock generation from cyclone3
hi,
i want to generate 216Hz clock from cyclone3 pll mega function with 8.192MHz as pll input , but pll is not supporting.
if i generated using logic elements is there any problem (with suitable i/p clock)?
is it possible to access all the 5 outputs of pll?
i hope u can help
thanks
    Is this question somehow related to the original post?
    In any case, you can use a counter for that.
    hi..please tell how to write
    vhdl code for frequency divider with 50% duty cycle.
    regards
    Use the output clock signal of one PLL as input to the second PLL.
    Lokla
    hi,
    please tell how to cascade plls in cyclone3
    regards
    krishnam raju
    I dont think you can get a 216MHz clock out of a 8.192 MHz input at all. At least not exactly. If you want to get close to it, you can try to cascade 2 PLLs, but not sure about JItter and clock quality.
    Lokla
